[phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/bbcode.php on line 471: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() 4x4norway.no • Se på emne - Avgas system ZD30
Det ser ut som att denna har en felles funktion med "värme brytern". Dvs, att när det är kallt och vi öker turtallet för och få runt vannet, så stryper denne avgasserna och därmed hjälper till med att värma upp lite grann. Även fått förslag som att det kan vara avgasbroms. Men det är är jag högst tveksam till att det finns på en vanlig bil, men jag kan ju ha fel.
