[phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 112: preg_match_all(): The /e modifier is no longer supported, use preg_replace_callback instead [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 114: array_unique() expects parameter 1 to be array, null given [phpBB Debug] PHP Warning: in file /includes/functions_reimg.php on line 116: Invalid argument supplied for foreach() 4x4norway.no • Se på emne - Ford Excursion Arctic Truck
Full kontroll av bremser i dag. Demontert og smurt opp alt av holdere. Glidere osv Klossene foran har nok står fast ei stund så må bestille nye .
Fik på nye klosser og nye sjims . Eine klossen var begynt å gå i oppløysnung. Skivene går holde ei stund til .
Sist endret av Roy Vårdal den 19/07/2020, 12:36, endret 1 gang
Lys i kupeen slår seg ikkje av . Leste av feilkoder ( ingen feil ) Logget systeme for dørlåser, fant ut at bilen registrerer åpen bakluke. Blei nød løsning på fjerning av kupe lys rele under ratte nå til å begynne med
Blei bytting av olje og filter i dag . Olje mengde 6.0 liter. Olje anbefalt av Ford.
Hadde vel på 6.2 før det var på max .
Sist endret av Roy Vårdal den 19/07/2020, 12:37, endret 1 gang
Bytting av bensin filter. ( står i ramma under førerdøra ) Lit kranglete koblinger . Usikker på om det er så let å demontere uten riktig verktøy .
Sist endret av Roy Vårdal den 19/07/2020, 12:39, endret 1 gang
Har hat ulyder fra servopumpa siden eg kjøpte bilen. Prøvde først å kjøre ein fluch på systemet men det hjalp ikkje. ( var ingen tegn til spon i oljen heldigvis ) Så da blei det ny pumpe og multireim. Lit trangt å grisete jobb men ok. Viktig å hat tilgjengelig riktig ters for å ta av og på reimhjulet. ( ikkje dra på ytterkanten av reimhjulet )
Sist endret av Roy Vårdal den 19/07/2020, 12:43, endret 1 gang
4x4 virker ikkje på auto funksjon. Har ikkje gjort det så lenge eg har hat den. Sund rusta vakum ventil på foraksel. Di ny som kom fra Rabek Bil var noe støre så blei ei midlertidig løysing med støre slange å overgang til original slange.
Sist endret av Roy Vårdal den 19/07/2020, 12:47, endret 1 gang
Blei nye bremse skiver freme i dag etter at eine caliperen hengte seg så pass at det blei kasst i eine skiva. Hadde heldigvis reserve caliper ligende.
Samtidig blei det montering av 50mm spacere rundt heile vogna
