frontin40 skrev:no not at all. I just ordered the 15x12.5 wheels yesterday from arctic truck themselves. Just waiting on confirmation from the sales rep. I hope i didnt get the wrong size since it seems everyone on this site has the 17x10.
You can use Mickey Thompson or Dick Cepek 15X10 rims, and adaptors to alter the bolt pattern to 6x5,5. (these spacers will move the mounting flange 3cm outwards.) But the range of usable rims available is much greater.
With this set-up you can use up to 37x12.5x15, gear ratios will not be good, but if you have at transmission it may work ok.
The gas milage will increase some. Arctic Trucks are working on a better gear ratio for the front axle. Must be rebuilt to fit an ARB locker. Costs a lot of money thow
About 50.000 Nkr. Rear axle is easy.
These are of course cut out bodywideners, but there are marked out places inside the wheelhouses which you can drill holes, and mount the wideners and drill through. Adjust well and mark the mounting position. apply mounting glue and glue and bolt them on to the car. This is a bit of work, the better job you do at this point, the better the result will be.
Deside for your self how much you want to remove from the original wheelhouses afterwards.
For further help, please ask and i will get someone to assist with more knowledge and better english....
