I'm in Africa right now on my way from Sweden to South Africa overland in 3 Patros. I need a transfer case main bearing, rear. Nissan says they don't have it in stock. As i recall it a quite common bearing and if I could get the dimensions it shouldn't be a problem to get it somewhere here in Addis Abeba, Ethiopia. Don't want to tear it down just to check.
It would be much appreciated.
It a TX12A tranfer fitted on a RD28T but i should be the same for TB and TD42. Nissan number: 3313933G01
