Fant denne på patrol4x4.com:
"I've fitted TB48 fronts to mine. They made a big difference. It stops now.
TB48 front rotors, calipers and master cylinder are all bigger, but bolt straight up. Splash guards are different, but they also bolt up. I also fitted braided lines from the diffs to the chassis.
TB48 rears are a different setup. They have the hand brake at the wheels, not on the tail shaft.
I tried TB48 pads in the original TD42 brakes, but didn't notice much difference."
Tror nok det blir nye bremser på turbil-nr2.....
E
